replacement of ic THCT12016
ismbn
Full Member level 3
Mumbai. india
Hi All ..
I want to Know, is there any replacement of this IC THCT12016...
I am using this to count the pulse of servo motor... i want to do the simulations also... so, is there any IC in proteus working like this...
also i am looking for other good simulation software...
Please suggest
Thanks Regards
Ismail
Hi Ismail,
The THCT12016 is an old device and one company did an FPGA replacement, but I am not sure if it is still available. There is one new device from iC-Haus - it is called the iC-MD. It is a direct quadrature encoder interface with three counters that can count up to 40MHz. There is an application note: https://www.ichaus.biz/wp2_simple_measurement and the datasheet is: https://www.ichaus.biz/MD . Simulation file I think are not available.
Enjoy your design work!
Reactions: ismbn
    ismbn
Hi Thanks for the reply...
there is some BiSS Interface is given here... can i use AVR to interface it???
Ismail
there is also an SPI-Interface to interface to the AVR.
Hi
Is there any other ic is available as simple as this ic... in with no SPI is needed
please guide
ismail
HI,
there war an FPGA replacement made, but I am not sure if it is still avaliable. Look at: **broken link removed**
