subwoofer board with high bass output
suvaraj
erode
hi friend
i need a subwoofer board with high bass output.pls help
Hello my friend
Would you like design it with yourself and some helps or you just want it's circuit ?
Best Wishes
Goldsmith
i need circuit and i would like to design my self pls help me
Again Hi
How much power do you need at out put and what is your out put impedance ?
I think you can use a baxandall filter at pri amp and you can use a butter worth filter at the out of your power amp .
Respectfully
Goldsmith
You need only the LP filter circuit or you want the full circuit with amplifier? If you need only Filter circuit then which amplifier you will be using, what is the input sensitivity of the main amplifier? Is this a main amplifier or is just meant for using to BASS amplification only?
