Xilinx register block
waleed82
Hello guys,
please don't mind me if my question is stupid but I am really new to this field. What is the use for XILINX REGISTER block??.
Thanks
What do you mean by "register block". Do you mean DFF?. Maybe could you elaborate your Q?, like where you found it, etc
Hi thanks for the reply yes the one I am asking about is DFF. Can you please help.
Thanks again
Sure.
DFF is a Dtype FlipFlop. A basic gate level element that can store 1-bit of information. This we also call as register. Because it can register(store) 1-bit of data for every clock it receives. A DFF works only if clock is provided. If the clock is @50MHz, then you can say that you are registering data @50MHz rate. A Xilinx D FF can have many types, for example DFF with set\reset, DFF with clock enable, etc. These are low level components that you may find inside the FPGA chip.
Please provide more details so that I can help you out exactly what you are looking for.
Thank you some much that's what I was looking for.
really appreciated:-D
