deathwaltz
Hi,I am a freshman in ASIC.
Now I am playing with ETS pre-layout STA in setup stage.
I am assuming that WLM model is working because the variable is set by this sentence.
set_var enable_wire_load_model_support 1
but actually, the net delay is 0.000 and this is displayed behind
Wireload model(.lib None Generated)
Because I don't fully understand all ASIC design flow, I am not sure where the problem is.
I assume that the WLM is not set in lib at the synthesis stage. Isn't it right?
Or I did sth wrong?
Thank you very much.:grin:
Or I did sth wrong?
