Why does my optimization run in HFFS?
denizduran
Member level 2
I am trying to construct a 4 element array antenna. My design goals; S11<-15dB and S21=S31=S41=S51<=-6dB has not been met. Hence I setup my parameters, defined my goals and tried to optimize my circuit. Even though it says "Optimization Analysis Done" I still get a blank page for my S-parameters result. It is as though the optimization did not go through. I have attached every step of what I did. I can add the .aedt HFSS file if necessary. Help will be much appreciated.
