Its SCHMITT TRIGGER not (Smith Trigger - Wrong), it ia basically a comparator with a feature of hysteresis. Applications usually in digital electronics and power converters
Thx All~
Is it means that the IC---LM311(Voltage comparator) is a kind of Schmitt trigger? Also I would like to ask what is the meaning of hysteresis? I know this term in Physics but why the Schmitt trigger has hysteresis?
Hysteresis is the difference between the input signal levels at which a comparator turns off and turns on. A small amount of hysteresis can be useful in a comparator circuit because it reduces the circuit's sensitivity to noise, and helps reduce multiple transitions at the output when changing state.
Sometimes, in a discrete design, there is a need to add an external resistor between the comparator's output and the positive input, creating a weak positive feedback loop. When the output makes a transition, the positive feedback slightly changes the positive input so as to reinforce the output change.
The LM311 Comparator IC is NOT a Schmitt Trigger device, but you can use it in a schmitt trigger circuit
