What is a voltage doubler and what is it used for?
Re: voltage doubler
usually it is charge pump circuit constructed from diode , capacitor and clock drivers. It's main purpose is to boost the input voltage to a higher voltage to
supply some circuit that need higher voltage to operate correctly.
application: LED driver, battery power system
Re: voltage doubler
murali sridhar.d,
It is a circuit that alternately charges capacitors in parallel, and then connects them in series. There are simple circuits using diodes that do this. You can also accomplish voltage tripling, quadrupling, etc. The disadvantage of these circuits is that the load regulation is poor. See the following:
h**p://hyperphysics.phy-astr.gsu.edu/hbase/electronic/voldoub.html
Regards,
Kral
Re: voltage doubler
murali sridhar.d said:
what is voltage doubler
and what is its application
See here for a working example:
