mohazaga
Full Member level 2
Hi ,,,
When designing IC , it's suggested to use specific off-chip pin type for each of I/O signal port. Vdda for power, Vssa for ground, Vin for in signal, and Vout for out signal. they also recommend to used Vddo. it's not connected to any port internal the chip. The Vddo pin is connected to all other I/O off-chip pins by ring of metal-3 in the chip layout.
What is the function of Vddo? why it's connected to all I/O off-chip pins? to which its connected externally?
Regards
Regards
