waveguide slotted antenna simulation , s-parameters not matching
sloty
Newbie level 6
i am trying to simulate 7-sloted waveguide antenna.for a sweep of 9-11 GHz.i am getting good gain of 14 dB.but when i am plotting S-parameters, they are not matching with theory.how can i find match?two ends of wave guide i defined as two ports.
kindly help
thanks
hi pls upload u file it may related to many thing and if u use a paper attach it too
Reactions: sloty
    sloty
i am attaching my hfss file, and the paper which i am trying to simulate.kindly help me.
thanks
sloty
  • study of slot antenna.pdf
  • slots.rar
1) How did you get a 14dB get when there is no radiation box?
2) I would have drawn one big radiation box and place a PEC slotted waveguide inside this box.
Hey seen your hfss file. You have not assign any material thats why your getting different results. Also for radiation, gain pattern you have to insert radiation box or sphere that will help you in calculation of gain.
All the best:)
Thank you all for seeing my file.
For Gain calculation i had included that Rad boundary.
If any one have solved waveguide slotted antenna file or tutorial on slotted antenna, kindly upload
thanks
hay
can any body suggest me how to measure Resonant Length of slot in slotted waveguide antenna , using HFSS software
