SuBill
Junior Member level 3
Dear all,
I'm doing an RF energy harvesting circuit in UHF band. My question is about the voltage multiplier. My 2-stage multiplier (using 2 HSMS-285C diodes) follows Karthaus-Fischer's voltage-doubler.
A 0.1F supercapacitor is put right at the output of the multiplier. This DC voltage will be provided to run an MCU and a sensor. The minimal voltage for operation of MCU and the sensor are 1.9V and 2.56V, respectively.
As in theory, the DC output voltage of the multiplier will be:
Vout = 4 * VRFpeak - 4 * Vfwd (forward voltage of the diodes) - Vload . So say, if Vpeak is 300mV, the maximum voltage I will get is 1.2V, ignoring Vfwd and Vload.
Here is the problem. When I measured the input AC voltage at the receiver antenna (Powercast) terminal, I got a very small signal with the maximum amplitude of 200 - 350mV. BUT I could get 2.6 VDC with full load as told above (MCU & sensor on full operation). Not all the times I could get this result, but sometimes I could. Please refer my picture below.
Probe1: Vin, RF
Probe 2: Vout
Please help me explain this phenomena. It seems my measurements went wrong, or my theory got sth wrong. Thank you very much.
Probe1: Vin, RF
Probe 2: Vout
