pigtwo
Member level 4
Hello all,
I have a fairly simple question about tasks with inputs. I've been working on this problem where I assign some values to a register then use those values as the input to a task. I've found that when I call the task the values it takes is the previous value of the input. I created an example to quickly show what I'm saying. In the below module I assign 'a' a value then give 'a' to a task which gives it to 'b'.
Below is the simulation output:
As you can see the task seems to get the previous value of 'a'. I've found the solution to this by adding a delay before I call the task but I'm curious about why this happens. Is it the simulator reording which statements are called first or is there something I don't understand about calling tasks? This seems strange to me because I'm using blocking assignments so the 'a = a + 1;' should have to finish before going to the task so I'm not sure why the task is getting the previous value. I must be missing something here.
Thank you!
Code Verilog - [expand] 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 module task_test( ); reg clk; reg[7:0] a, b; initial begin forever #5 clk = ~clk; end initial begin clk = 0; a = 0; b = 0; #10 while(1) begin a = a + 1; give(a,b); end end task give; input[7:0] x; output[7:0] y; begin y = x; @(posedge clk); end endtask endmodule
Thank you!
