Alicoder
Newbie
I have a VCS filelist which i am passing with command vlogan -f flist.vcs. However, the flist.vcs format is like:
+incdir+${CURR_DIR}/something
if {$env(FLIST) eq _old}
-f ${OLD_DIR}/flist.old
else
-f ${NEW_DIR}/flist.new
where FLIST is env variable
It throws error like this:
Warning-[PMFO] Potential misusage of '-f/-F' option
Potential misusage of '-f/-F' option, which can only be used in non-UUM
flow.
The option '-f/-F' cannot be used in UUM flow.It could cause an error saying
that the top unit is treated as source file in the UUM flow.If VCS is
intended to be run in non-UUM flow, please check if source files are
specified correctly.Otherwise please use '-file' option for UUM flow.
Error-[SFCOR] Source file cannot be opened
Source file "if" cannot be opened for reading due to 'No such file or
directory'.
Please fix above issue and compile again.
else
flow.
directory'.
