Variable length Correlation in VHDL
Okey ;
Thank you ;
use IEEE.math_real.all;
use IEEE.math_real."ceil";
use IEEE.math_real."log2";
1. ceil and log2 are part of math_real. The first line should already include it. In case of doubt review the library definition of your VHDL tool.
2. the additional lines have wrong syntax
For the easy option, you need to just make everything the output length from the beginning.
something like this:
Code VHDL - [expand]
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
32
33
type mult_array_t is array(0 to longueur-1) of signed(15 downto 0);
type adder_stage_t is array(0 to longueur/2-1) of signed(Q'length-1 downto 0);
type adder_tree_t is array(0 to log2(longueur)-1) of adder_stage_t;
signal mults : mult_array_t;
signal adders : adder_tree_t;
--multiplies:
mult_proc : process(clk)
begin
  if rising_edge(clk) then
    for i in mults'range loop
      mults(i) <= ip(i) * C(i);
    end loop;
    --initial adders:
    for i in adders(0)'range loop
      adders(0)(i) <= resize(mults(i*2), Q'length) + resize( mults(i*2 +1), Q'length);
    end loop;
    --other adder stages:
    for level in 1 to adders'high loop
      for i in 0 to longueur/ (2**(level+1)) loop
        adders(level)(i) <= adders(level-1)(i*2) + adders(level-1)(i*2 + 1);
      end loop
    end loop;
  end if;
end process;
Q <= adders(adders'high)(0);
Doing this, the synthesisor can trim any unused bits.
Thank you ;)
Thank you ;)
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
32
33
--multiplies:
begin
    end loop;
    --initial adders:
    end loop;
      end loop
    end loop;
  end if;
end process;
Thank you My friends
