hi
yes u can surely use generic statement in order to make a n- i/p gate.
Below i am putting the Code for a simple N- i/p AND gate.
But i wud suggest u to please go and read some relevent Books like J. Bhasker and Perry for the basiocs as the question u hav asked is a simple basic Question.
library ieee;
use ieee.std_logic_1164.all;
entity gen_and is
generic( N: integer:=2);
port ( a,b : in std_logic;
c : out std_logic);
end entity;
Architecture arch1 of gen_and is
begin
c<=a and b;
end arch1;
entity gen is
end entity;
Architecture arch of gen is
signal ip,op: std_logic;
component
gen_and is
c : out std_logic);
end component;
begin
A1: gen_and generic map( 4) port map (ip,op);
The code you posted is not an n-input AND gate buddy, actually it is just a 2-input AND.
You define a generic parameter N but you don't use it, so what's the point?
What I am asking is below...
By the way, I have the two books as hardcopy that you've mentioned, thank you for your advice
i1--------|
i2--------|
i3--------|
.---------| AND ----> F
in--------|
