urgent I can not send sms from mcu and gsm modem to moblie???
Ni yanfang
Member level 3
Hi I am using AT89C51 mcu connect with gsm modem . I need to write AT command using c language to run my program. But the code is not working and can not send sms to mobile. Kindly che check for me the below code. I just need press p1^3 button then the prgram can send sms. I did not need receive reply because i did not connect LCD. And i have not ideal how to add LED p3^6 in this program to indicate on and off. This means led on when sending sms or led off when device is not sending sms. Kindly help please.
Code C - [expand]
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
#include <reg51.h>
#include <stdio.h>
sbit irout=P1^3;
sbit rs=P2^0;
sbit rw=P2^1;
sbit e=P2^2;
void serial_init(void);
void delay(int);
   SCON = 0x50;
   TMOD = 0x20;
   TH1   = 0xFD;
   TR1   = 1;
   TI   = 1;
void serial(void) interrupt 4
unsigned int y[25];
if(RI==1)
y[25]=SBUF;
RI=0;
void delay(int n)
   int i,j;
   for(i=0;i<n;i++)
   for(j=0;j<1000;j++);
void main(void)
IE=0x90;
irout=1;
irout=0;
while(1)
{       if(irout==1)
        delay(200);
        serial_init();
        printf("AT+CMGF=1%c",13);
        delay(200);
        printf("AT+CMGS=\"92207869\"%c",13);
        delay(200);
        printf("Hi :-) GSM Modem Test");
        delay(20);
        printf("%c",0x1A);
        delay(200);
        while(irout==1);
Hello there,
Try these links
Best regards,
void main(void)
IE=0x90;
irout=1;
irout=0;
while(1)
{ if(irout==1)
delay(200);
serial_init();
delay(200);
Try,
Code C - [expand]
8
9
10
11
12
13
14
void main(void)
IE=0x90;
irout=1;
irout=0;
[B]serial_init(); [/B]
while(1)
{ if(irout==1)
delay(200);
delay(200);
Hello there,
Try these links
Best regards,
Try,
void main(void)
IE=0x90;
irout=1;
irout=0;
serial_init();
while(1)
{ if(irout==1)
delay(200);
delay(200);
I try already. but still can not send sms. do you have any ideal?
Hello there,
sbit Led1=P3^6;// P3.6 in become GPIO.(add after #include)
Led1=1;// led become high
led1=0;// led become low.
use above logic and update your code.
Have tried with Hyperterminal?? Please connect the gsm module with your PC hyper terminal and try.
Are you sure about your hardware connection ?? please verify once again (mainly TX(GSM)--> RX(MCU)).
update me
  • Interface GSM Module with 8051 microcontroller (AT89C51) using PC circuit.gif
Try connecting your GSM modem with the PC and you can try the AT commands through hyperterminal.
Also the sending of message format inlcudes country code to be specified along with the no. check that too. use +1 (if in USA), likewise..
After it is verifed then check on the board.
