Trishool
Full Member level 1
- Joined
- Jul 12, 2001
- Messages
- 97
- Helped
- 1
- Reputation
- 2
- Reaction score
- 0
- Trophy points
- 1,286
- Location
- Himalayas.(mount K2)
- Activity points
- 821
how to reduce the inductance of a 3 loop antenna
Hello Guys ,
Please have a look at the following loop(15mm length 2mm thick) antenna for 432Mhz Transmitter hand held device ,which is for PCB. I want to know about the following;
1) What value of Variable capacitor to select (PCB is FR4 , 1.6mm thick standard).
2) Can loop be made small if yes what dimension.
Thank you
-Ts
Hello Guys ,
Thank you
-Ts
