transition/matching between IC and parallel strip feed lines
cer75
Hi all,
Could someone give a hint of how to do the transition between:
1- Tx single-ended IC (G-S-G, IC pads) - and - Parallel strip feed lines (at both sides of the substrate, NO coplanar) of a flat dipole antenna.
2- Parallel strip feed lines (at both sides of the substrate, NO coplanar) of a flat dipole antenna - and - Rx differential IC (G-S-G-S-G) pads.
I have to achieve BW around 10% at frequency around 60GHz.
Any related link, book, article/pdf is wellcome!
Thank you in advance!
