To what is led centre pad connected?..anode or cathode?
Z
zenerbjt
Do you know to what is connected the middle pad of this LED, anode or cathode, -datasheet doesn’t say?
XLAMP XP-E2 LED
I assume the pad you are reffering to is the middle one, between anode and cathode shown on page 10.
This should be a themal pad, and should therefore be connected to a copper plane which has a low thermal resistance. This might be your GND plane and if your cathode is also connected to GND, this two pads can be directly connected.
BR
Reactions: zenerbjt
    Z
first page of datasheet says: "• electrically neutral thermal path".
In my eyes this says it is electrically isolated...
Klaus
