sanjanavee
Newbie level 5
Can anyone tell me whats wrong with this program??
library ieee;
use ieee.std_logic_1164.all;
use ieee.std_logic_arith.all;
use ieee.std_logic_unsigned.all;
entity top is
port
clk_in : in std_logic;
reset : in std_logic;
WEN : in std_logic; -- taken as active high
REN : in std_logic; -- taken as active high
WADDR : in std_logic_vector(11 downto 0);
RADDR : in std_logic_vector(11 downto 0);
ram_dout : out std_logic_vector(2 downto 0);
end top;
architecture rtl of top is
component VCC
port( Y : out std_logic);
end component;
component GND
end component;
component counter
port
clk : in std_logic;
sel : in std_logic;
qa : out std_logic_vector(2 downto 0);
qb : out std_logic_vector(2 downto 0)
end component;
component RAM4K9
generic (MEMORYFILE:string := "");
port
ADDRA11, ADDRA10, ADDRA9, ADDRA8, ADDRA7, ADDRA6,
ADDRA5, ADDRA4, ADDRA3, ADDRA2, ADDRA1, ADDRA0, ADDRB11,
ADDRB10, ADDRB9, ADDRB8, ADDRB7, ADDRB6, ADDRB5, ADDRB4,
ADDRB3, ADDRB2, ADDRB1, ADDRB0, DINA8, DINA7, DINA6,
DINA5, DINA4, DINA3, DINA2, DINA1, DINA0, DINB8, DINB7,
DINB6, DINB5, DINB4, DINB3, DINB2, DINB1, DINB0, WIDTHA0,
WIDTHA1, WIDTHB0, WIDTHB1, PIPEA, PIPEB, WMODEA, WMODEB,
BLKA, BLKB, WENA, WENB, CLKA, CLKB, RESET : in std_logic :=
'U'; DOUTA8, DOUTA7, DOUTA6, DOUTA5, DOUTA4, DOUTA3,
DOUTA2, DOUTA1, DOUTA0, DOUTB8, DOUTB7, DOUTB6, DOUTB5,
DOUTB4, DOUTB3, DOUTB2, DOUTB1, DOUTB0 : out std_logic
end component;
signal VCC_1_net : std_logic;
signal GND_1_net : std_logic;
signal ram_din : std_logic_vector(2 downto 0);
signal RENB : std_logic;
begin
RENB <= not (REN);
VCC_2_net : VCC
port map
Y => VCC_1_net
GND_2_net : GND
port map
Y => GND_1_net
u_counter : counter
port map
clk => clk_in,
reset => reset,
sel => VCC_1_net,
qa => ram_din,
qb => open
newCore_R0C0 : RAM4K9
port map
ADDRA11 => WADDR(11),
ADDRA10 => WADDR(10),
ADDRA9 => WADDR(9),
ADDRA8 => WADDR(8),
ADDRA7 => WADDR(7),
ADDRA6 => WADDR(6),
ADDRA5 => WADDR(5),
ADDRA4 => WADDR(4),
ADDRA3 => WADDR(3),
ADDRA2 => WADDR(2),
ADDRA1 => WADDR(1),
ADDRA0 => WADDR(0),
ADDRB11 => RADDR(11),
ADDRB10 => RADDR(10),
ADDRB9 => RADDR(9),
ADDRB8 => RADDR(8),
ADDRB7 => RADDR(7),
ADDRB6 => RADDR(6),
ADDRB5 => RADDR(5),
ADDRB4 => RADDR(4),
ADDRB3 => RADDR(3),
ADDRB2 => RADDR(2),
ADDRB1 => RADDR(1),
ADDRB0 => RADDR(0),
DINA8 => GND_1_net,
DINA7 => GND_1_net,
DINA6 => GND_1_net,
DINA5 => GND_1_net,
DINA4 => GND_1_net,
DINA3 => GND_1_net,
DINA2 => ram_din(2),
DINA1 => ram_din(1),
DINA0 => ram_din(0),
DINB8 => GND_1_net,
DINB7 => GND_1_net,
DINB6 => GND_1_net,
DINB5 => GND_1_net,
DINB4 => GND_1_net,
DINB3 => GND_1_net,
DINB2 => GND_1_net,
DINB1 => GND_1_net,
DINB0 => GND_1_net,
WIDTHA0 => GND_1_net, -- Idont know what these pins will do
WIDTHA1 => GND_1_net, -- means the purpose of these
WIDTHB0 => GND_1_net, -- WIDTHAn and WIDTHBn
WIDTHB1 => GND_1_net,
PIPEA => GND_1_net, -- Dont know this pin plese check and correct the map
PIPEB => VCC_1_net, -- Dont know this pin plese check and correct the map
WMODEA => GND_1_net, -- Dont know this pin plese check and correct the map
WMODEB => GND_1_net, -- Dont know this pin plese check and correct the map
BLKA => VCC_1_net, -- Dont know this pin plese check and correct the map
BLKB => RENB, -- Dont know this pin plese check and correct the map
WENA => WEN, -- Dont know this pin plese check and correct the map
WENB => GND_1_net, -- Dont know this pin plese check and correct the map
CLKA => clk_in, -- Both write and read
CLKB => clk_in, -- using the same clock
RESET => reset,
DOUTA8 => OPEN,
DOUTA7 => OPEN,
DOUTA6 => OPEN,
DOUTA5 => OPEN,
DOUTA4 => OPEN,
DOUTA3 => OPEN,
DOUTA2 => OPEN,
DOUTA1 => OPEN,
DOUTA0 => OPEN,
DOUTB8 => OPEN,
DOUTB7 => OPEN,
DOUTB6 => OPEN,
DOUTB5 => OPEN,
DOUTB4 => OPEN,
DOUTB3 => OPEN,
DOUTB2 => ram_dout(2),
DOUTB1 => ram_dout(1),
DOUTB0 => ram_dout(0)
end rtl;
library ieee;
entity top is
port
end top;
component VCC
end component;
component GND
end component;
component counter
port
clk : in std_logic;
sel : in std_logic;
end component;
component RAM4K9
port
end component;
begin
RENB <= not (REN);
VCC_2_net : VCC
port map
Y => VCC_1_net
GND_2_net : GND
port map
Y => GND_1_net
u_counter : counter
port map
clk => clk_in,
reset => reset,
sel => VCC_1_net,
qa => ram_din,
qb => open
port map
ADDRA9 => WADDR(9),
ADDRA8 => WADDR(8),
ADDRA7 => WADDR(7),
ADDRA6 => WADDR(6),
ADDRA5 => WADDR(5),
ADDRA4 => WADDR(4),
ADDRA3 => WADDR(3),
ADDRA2 => WADDR(2),
ADDRA1 => WADDR(1),
ADDRA0 => WADDR(0),
ADDRB9 => RADDR(9),
ADDRB8 => RADDR(8),
ADDRB7 => RADDR(7),
ADDRB6 => RADDR(6),
ADDRB5 => RADDR(5),
ADDRB4 => RADDR(4),
ADDRB3 => RADDR(3),
ADDRB2 => RADDR(2),
ADDRB1 => RADDR(1),
ADDRB0 => RADDR(0),
DINA8 => GND_1_net,
DINA7 => GND_1_net,
DINA6 => GND_1_net,
DINA5 => GND_1_net,
DINA4 => GND_1_net,
DINA3 => GND_1_net,
DINB8 => GND_1_net,
DINB7 => GND_1_net,
DINB6 => GND_1_net,
DINB5 => GND_1_net,
DINB4 => GND_1_net,
DINB3 => GND_1_net,
DINB2 => GND_1_net,
DINB1 => GND_1_net,
DINB0 => GND_1_net,
RESET => reset,
DOUTA8 => OPEN,
DOUTA7 => OPEN,
DOUTA6 => OPEN,
DOUTA5 => OPEN,
DOUTA4 => OPEN,
DOUTA3 => OPEN,
DOUTA2 => OPEN,
DOUTA1 => OPEN,
DOUTA0 => OPEN,
DOUTB8 => OPEN,
DOUTB7 => OPEN,
DOUTB6 => OPEN,
DOUTB5 => OPEN,
DOUTB4 => OPEN,
DOUTB3 => OPEN,
end rtl;
