synchronous vs asynchronous
anoop12
Member level 5
can anyone differentiate between synchronous and asynchronous signals in terms of VHDL
regards
if clk is used then synchronous otherwise asynchronous.
if clk'event and clk='1' then
y<= x;
z<=k;
;;;;synchronous.
Signals controlled by the clock event is called as synchronous.
If the internal signal driven by the other signal which comes under the clock then first signal will also became the synchronous
Hi.
Synchronous reset in VHDL.
if (clk'event and clk='1') then
if reset = '1' then
elsif
end if;
end if;
Asynchronous reset in VHDL
if reset='1' then
elsif clk'event and clk='1' then
end if;
Hope it helps
the important thing is not the difference between sync and async signals.... are preparing an interview?
