thisistausif
Member level 2
__delay_cycles
Hello experts,
i`m having stability problem with my msp430 ADC12 while using a
ref3033 refrence generator too, its not working well, the averaged
value of binary from ADC12MEM0 is quite stable but not the double
value which i get after some calculation on that binary value.
here is the code for that written in IAR, please suggest if this can
be solved by the some change in code,
thanks for the help.
Tausif.
#include <MSP430x13x.h>
#include <math.h>
#include <stdlib.h>
#include <string.h>
void MSP430_Init_HW( void);//intialise hardware
void init_ADC(void);//intialise ADC
void wr_lcd_ir(int inst);// write lcd instruction register
void wr_lcd_dr(char data);// write lcd data register
int rd_lcd_sr(void);// read lcd status register
void init_lcd(void);// initialise lcd
void display_string( char * str, int cnt);// display string
void writeValue(double value,int unit);//write value to lcd
void itoa(unsigned int n, char s[], int * cnt); // number to string
void reverse(char s[]); // reverse string
// Main routine
void main(void)
MSP430_Init_HW( ); //initialize MCU
init_lcd(); //initialize lcd
display_string( "my test ",8);
//__delay_cycles( 2000000);
wr_lcd_ir(0xc0);//seting to line 2
//__delay_cycles( 20000);
display_string( "program",7);
wr_lcd_ir(0x01); //clear display
double b=0.0,d=0.0,befz = 0.0 ;// b=>unit 1 d=> unit 2 befz=>value before zero adjustment
int unit=1,tmp=0xff;// unit selecteo
unsigned long avrv;
unsigned short inva=0,inv[8] =
{3180,3180,3180,3180,3180,3180,3180,3180};//invafz;
double zero_ram = 0.0;
unsigned short Adcinb[64];
for(int i=0;i<=63;i++)
Adcinb = 3180;
double *Flash_ptrA;
init_ADC();//initialise ADC12
checkinput:// check input at ADC12MEM0
ADC12IFG=0;
__delay_cycles( 200);
ADC12IFG=0;
if(ADC12IFG==0)
goto checkinput;
Adcinb[63]=Adcinb[62];
Adcinb[62]=Adcinb[61];
Adcinb[61]=Adcinb[60];
Adcinb[60]=Adcinb[59];
Adcinb[59]=Adcinb[58];
Adcinb[58]=Adcinb[57];
Adcinb[57]=Adcinb[56];
Adcinb[56]=Adcinb[55];
Adcinb[55]=Adcinb[54];
Adcinb[54]=Adcinb[53];
Adcinb[53]=Adcinb[52];
Adcinb[52]=Adcinb[51];
Adcinb[51]=Adcinb[50];
Adcinb[50]=Adcinb[49];
Adcinb[49]=Adcinb[48];
Adcinb[48]=Adcinb[47];
Adcinb[47]=Adcinb[46];
Adcinb[46]=Adcinb[45];
Adcinb[45]=Adcinb[44];
Adcinb[44]=Adcinb[43];
Adcinb[43]=Adcinb[42];
Adcinb[42]=Adcinb[41];
Adcinb[41]=Adcinb[40];
Adcinb[40]=Adcinb[39];
Adcinb[39]=Adcinb[38];
Adcinb[38]=Adcinb[37];
Adcinb[37]=Adcinb[36];
Adcinb[36]=Adcinb[35];
Adcinb[35]=Adcinb[34];
Adcinb[34]=Adcinb[33];
Adcinb[33]=Adcinb[32];
Adcinb[32]=Adcinb[31];
Adcinb[31]=Adcinb[30];
Adcinb[30]=Adcinb[29];
Adcinb[29]=Adcinb[28];
Adcinb[28]=Adcinb[27];
Adcinb[27]=Adcinb[26];
Adcinb[26]=Adcinb[25];
Adcinb[25]=Adcinb[24];
Adcinb[24]=Adcinb[23];
Adcinb[23]=Adcinb[22];
Adcinb[22]=Adcinb[21];
Adcinb[21]=Adcinb[20];
Adcinb[20]=Adcinb[19];
Adcinb[19]=Adcinb[18];
Adcinb[18]=Adcinb[17];
Adcinb[17]=Adcinb[16];
Adcinb[16]=Adcinb[15];
Adcinb[15]=Adcinb[14];
Adcinb[14]=Adcinb[13];
Adcinb[13]=Adcinb[12];
Adcinb[12]=Adcinb[11];
Adcinb[11]=Adcinb[10];
Adcinb[10]=Adcinb[9];
Adcinb[9]=Adcinb[8];
Adcinb[8]=Adcinb[7];
Adcinb[7]=Adcinb[6];
Adcinb[6]=Adcinb[5];
Adcinb[5]=Adcinb[4];
Adcinb[4]=Adcinb[3];
Adcinb[3]=Adcinb[2];
Adcinb[2]=Adcinb[1];
Adcinb[1]=Adcinb[0];
Adcinb[0]=ADC12MEM0;
avrv=0;
avrv = avrv + Adcinb;//adding for average
//average of binary values
//taking avrage of averaged binary
inv[7]=inv[6];
inv[6]=inv[5];
inv[5]=inv[4];
inv[4]=inv[3];
inv[3]=inv[2];
inv[2]=inv[1];
inv[1]=inv[0];
inv[0]=avrv/64;//average of binary values
inva = 0;
for(int i=0;i<=7;i++)
inva = inva + inv;
inva= inva/8; // average of averaged value
befz = 0.08217577087*inva-254.9316528; //converting binary value
to value of unit 1
//retriving value from flash
Flash_ptrA = (double *) 0x1080; //initialsie pointer
zero_ram = *Flash_ptrA; // copy from flash to ram
b = befz - zero_ram; //corrected value
// check unit key pressed
//tmp1 = P5IN;
tmp = P5IN | 0xf8;
if( tmp == 0xfe )
unit =1; // mm
else if ( tmp == 0xfd)
unit =2; // inch
else if ( tmp == 0xfb )
unit =0; // pascal
else if ( tmp == 0xf9 )
zero_ram = befz;
// Flash pointer
Flash_ptrA = (double *) 0x1080; // Initialize
Flash pointer
FCTL1 = FWKEY + ERASE; // Set Erase bit
FCTL3 = FWKEY; // Clear Lock bit
*Flash_ptrA = 0; // Dummy write to
erase Flash segment
FCTL1 = FWKEY + WRT; // Set WRT bit for
write operation
{ *Flash_ptrA = zero_ram;
// Write value to flash
FCTL1 = FWKEY; // Clear WRT bit
FCTL3 = FWKEY + LOCK; // Set LOCK bit
__delay_cycles( 2000);
/*if( b >= 50.0)//( d >= 490.3325)
display_string("OVERFLOW",8); //overflow seting
goto checkinput;
}else if( b <= -25.0)//( d <= -245.16625)
goto checkinput;
//display sign // check for sign
if(unit ==1) // display in mm
if(b<0)
{ wr_lcd_ir(0x80);//seting to line 1#2
wr_lcd_dr('-');
else
wr_lcd_dr('+');
wr_lcd_ir(0xc1);//seting to line 2#1
display_string("MM WC",5);
wr_lcd_ir(0x81);//seting to line 1#3
writeValue(b,unit);
else if( unit == 2 ) // display in inch
display_string("ADCM ",5);
wr_lcd_ir(0x81);//setting to line 1#3
writeValue(inva,unit);
else if(unit == 0) // display in pascal
d=b*9.8;
if(d<0)
wr_lcd_dr('-');
else
wr_lcd_dr('+');
wr_lcd_ir(0xc3);//seting to line 2#3
display_string("Pa",2);
wr_lcd_ir(0x81);// srtting to line 1#3
writeValue(d,unit);
__delay_cycles( 60000);
goto checkinput;
// [Watchdog Timer]
WDTCTL=0x5A00 | 0x80;
// [Port 1/2]
P1OUT=P1IN;
P1DIR=0xFF;
P2OUT=P2IN & ~0x01; //P2.0 is LCD_E
P2DIR=0xFF;
// [Port 3/4]
// P3DIR=0x00; //P3.x are LCD_DBx
P4OUT=P4IN & ~0x18; //P4.4 is LCD_R/W, P4.3 is LCD_RS
P4DIR=0xFF;
// [Port 5/6]
P5OUT=P5IN;
P5DIR=0xF8; //P5.2, P5.1, P5.0 are push buttons
// initialise ADC
void init_ADC()
P6SEL |= 0x01; // Enable A/D channel A0
ADC12CTL0 = !REFON; //off internal reference
ADC12CTL0 |= ADC12ON+SHT0_15+MSC; // Turn on ADC12,
set sampling time
ADC12CTL1 = SHP+CONSEQ_2+ADC12DIV_7; // Use
sampling timer, set mode
ADC12IE = 0x01; // Enable ADC12IFG.0
ADC12MCTL0 = SREF_0; // external reference
ADC12MCTL0 |= INCH_0; //SELECT A0
ADC12CTL0 |= ENC; // Enable conversions
ADC12CTL0 |= ADC12SC; // Start conversion
//_BIS_SR( GIE); // Enter LPM0,Enable interrupts
P4OUT&=~0x18; //R/W=Wr, RS=Ir
P2OUT|=0x01; //set E
P3OUT=inst; //load DB
P3DIR=0xFF; //drive DB
P2OUT&=~0x01; //clear E
P3DIR=0x00; //float DB
P4OUT&=~0x10; //R/W=Wr
P4OUT|=0x08; //RS=Dr
P3OUT=data; //load DB
int rd_lcd_sr(void)
P4OUT|=0x10; //R/W=Rd
P4OUT&=~0x08; //RS=Sr
int status=P3IN; //read status
return (status);
// initialise lcd
void init_lcd(void)
__delay_cycles( 20000); // ~20000us @ ~1MHz
wr_lcd_ir(0x30) ;
__delay_cycles( 5500); // ~5500us @ ~1MHz
wr_lcd_ir(0x30) ;
__delay_cycles( 150); // ~150us @ ~1MHz
wr_lcd_ir(0x30) ;
while ((rd_lcd_sr( )&0x80)!= 0) {};
wr_lcd_ir(0x3c) ; //8-bit, 2-line, 5x10
wr_lcd_ir(0x01) ; //clear-display
wr_lcd_ir(0x0C) ; //display-on, cursor-off, blink-off
wr_lcd_ir(0x06) ; //increment, shift-off
// display string
for (int i=0; i<cnt; i++)
wr_lcd_dr(str[ i]);
// write numeric value on lcd
char res[7];
unsigned int d1=0,d2=0;
int cntd=0, cntreal=0; //real;
// number to out put.
d1 = (unsigned int) fabs(value);
res[0]='\0';
//d1=fabs(d1);
if(d1==0)
wr_lcd_dr('0');
else
itoa(d1,res,&cntd);
//num2str ( d1, res, &cntd ); // convert interger
display_string(res, cntd); // display integer part
if( unit == 1|unit == 2) // 1- mm 2 inch 3 pascal
if( cntd <=7)
//wr_lcd_dr('0');
wr_lcd_dr('.');
// convert real and print
if( cntd <=2 && unit == 1)
d2 = (unsigned int) abs(( value - d1 ) * 1000000); // get
6 digits of real part
itoa( d2, res, &cntreal );
//num2str ( d2, res, &cntreal ); // convert real part (6
digits ) to string
wr_lcd_dr(res[0]);
/*if( cntd <=5)
wr_lcd_dr( res[1]);}
if( cntd <= 4)
wr_lcd_dr(res[2]);
if( cntd <= 3)
wr_lcd_dr(res[3]);
if( cntd <= 2)
wr_lcd_dr(res[4]);
if( cntd <= 1)
wr_lcd_dr(res[5]);*/
d2 = ( value - d1 ) * 100000; // get 6 digits of real part
itoa ( d2, res, &cntreal ); // convert real part (6 digits )
to string
wr_lcd_dr(res[0]);
if(unit == 2)
if( cntd <=5)
wr_lcd_dr( res[1]);
if(unit == 2){
if( cntd <=4)
wr_lcd_dr( res[2]);
///// end of printing values
/* itoa: convert n to characters in s */
void itoa(unsigned int n, char s[], int *cnt)
int i, sign;
if ((sign = n) < 0) /* record sign */
n = -n; /* make n positive */
i = 0;
do { /* generate digits in reverse order */
s[i++] = n % 10 + '0'; /* get next digit */
} while ((n /= 10) > 0); /* delete it */
if (sign < 0)
s[i++] = '-';
s = '\0';
*cnt=i;
reverse(s);
/* reverse: reverse string s in place */
int c, i, j;
for (i = 0, j = strlen(s)-1; i<j; i++, j--) {
c = s;
s = s[j];
s[j] = c;
Hello experts,
Tausif.
#include <math.h>
#include <stdlib.h>
#include <string.h>
// Main routine
void main(void)
unsigned long avrv;
Adcinb = 3180;
double *Flash_ptrA;
ADC12IFG=0;
ADC12IFG=0;
if(ADC12IFG==0)
goto checkinput;
avrv=0;
inv[7]=inv[6];
inv[6]=inv[5];
inv[5]=inv[4];
inv[4]=inv[3];
inv[3]=inv[2];
inv[2]=inv[1];
inv[1]=inv[0];
inva = 0;
inva = inva + inv;
to value of unit 1
//tmp1 = P5IN;
tmp = P5IN | 0xf8;
if( tmp == 0xfe )
unit =1; // mm
unit =2; // inch
unit =0; // pascal
zero_ram = befz;
// Flash pointer
Flash pointer
erase Flash segment
write operation
goto checkinput;
goto checkinput;
if(b<0)
wr_lcd_dr('-');
else
wr_lcd_dr('+');
writeValue(b,unit);
d=b*9.8;
if(d<0)
wr_lcd_dr('-');
else
wr_lcd_dr('+');
writeValue(d,unit);
goto checkinput;
// [Watchdog Timer]
// [Port 1/2]
P1OUT=P1IN;
P1DIR=0xFF;
P2DIR=0xFF;
// [Port 3/4]
P4DIR=0xFF;
// [Port 5/6]
P5OUT=P5IN;
// initialise ADC
void init_ADC()
set sampling time
int rd_lcd_sr(void)
return (status);
// initialise lcd
void init_lcd(void)
wr_lcd_ir(0x30) ;
wr_lcd_ir(0x30) ;
wr_lcd_ir(0x30) ;
// display string
wr_lcd_dr(str[ i]);
char res[7];
res[0]='\0';
//d1=fabs(d1);
if(d1==0)
wr_lcd_dr('0');
else
itoa(d1,res,&cntd);
if( cntd <=7)
//wr_lcd_dr('0');
wr_lcd_dr('.');
digits ) to string
wr_lcd_dr(res[0]);
/*if( cntd <=5)
if( cntd <= 4)
wr_lcd_dr(res[2]);
if( cntd <= 3)
wr_lcd_dr(res[3]);
if( cntd <= 2)
wr_lcd_dr(res[4]);
if( cntd <= 1)
to string
wr_lcd_dr(res[0]);
if(unit == 2)
if( cntd <=5)
wr_lcd_dr( res[1]);
if(unit == 2){
if( cntd <=4)
wr_lcd_dr( res[2]);
int i, sign;
i = 0;
if (sign < 0)
s[i++] = '-';
s = '\0';
*cnt=i;
reverse(s);
int c, i, j;
c = s;
s = s[j];
s[j] = c;
