Spice automated plot possible?
Cubrilo
Junior Member level 1
Russia
Hi Spice experts!
Is it possible to have automated plot in spice (PSpice)? Instead, now I'm running transient simulation, then plot and save what I need manually, then change source/parameter and run again... Is it possible to do it simply like in matlab:
for counter
hold
axis(settings);
plot(variables);
end.
P.S. Parametric sweep doesn't help me because I need AC
you can check with a command line version like ngspice for your requirement.
in pspice , maybe , param command (if settable through ) may suit.
Thank you both. I didn't explain precisely at the first place.
Particularly I need AC sweep but with switching therefore non-linear - classic AC sweep is not useful.
Yes, parametric would be more suitable, I can specify the points I want to be analyzed, but this is transient (time) analysis, I have to plot frequency manually again.
Any thoughts?
AC analysis per definition always is a linear and small signal analysis. Thus - if there are time dependent switches in the circuit, you only can do a TRAN analysis.
