Araxnid
Newbie level 6
Hello everyone.
I was working with spi module and encoutered some problem -
My code - SPI module(it's not finished yet):
and my top_module file:
So, XILINX ISE saying me that:
WARNING:Xst:1305 - Output <ser_OUTPUT> is never assigned. Tied to value 0.
WARNING:Xst:646 - Signal <ser_OTPUT> is assigned but never used. This unconnected signal will be trimmed during the optimization process.
WARNING:Xst:1780 - Signal <counter> is never used or assigned. This unconnected signal will be trimmed during the optimization process.
WARNING:Xst:653 - Signal <par_INPUT> is used but never assigned. This sourceless signal will be automatically connected to value 0.
I cant understand why its thinking that ser_OUTPUT is never assigned? Its assigned to load, and load shifts every clk cycle.... test_signal is special signal from my board which will pull down CS and activate SPI module. Can anyone explain what im doing wrong with this? Thanks.
module ParallelToSerial(
input CLK,
input [15:0]par_INPUT,
input enable,
output ser_OUTPUT,
output SCLK,
output CS
reg [15:0]load;
reg [6:0]counter;
assign ser_OTPUT=load[0];
assign SCLK=CLK;
assign CS = enable;
always @(negedge enable) begin
load=par_INPUT;
end
always @(posedge CLK) begin
if (enable==1'b0) begin
load=load[0] & load[15:1];
end
end
endmodule
module top_module(
input CLK,
output MOSI,
input test_signal,
output SCLK,
output CS
reg enable = 1'b1;
reg par_INPUT = 16'd3054;
if (test_signal==1'b1) begin
enable = 1'b0;
end
end
ParallelToSerial u1(.CLK(CLK),.par_INPUT(par_INPUT),.enable(enable),.ser_OUTPUT(MOSI),.SCLK(SCLK),.CS(CS));
endmodule
