vbdev
Yes, you are absolutely correct. I also had the same thought because even the battery voltage was raised to 16V there was still no charging current. I will post the results with a good battery along with your suggested modifications (22uF capacitor across variable resistor).
Can you please explain the operation of MOSFETs in the circuit I have recently added!!!
![Charge Controller.png Charge Controller.png](https://www.edaboard.com/data/attachments/42/42805-df2399fc0f07ecac9f7c9adabdebdac5.jpg)
Thanks!!!
Sorry I had not read your full text. Is the right side FET is used for current limiting? Should I include it in my circuit?
Thanks!!!
