Servo tester with picf675 in basic. Help identify compiler ?
nilses
Member level 2
Hello,
I found this servo tester on internet and I'm wondering what kind of compiler was used to make this program.
Any ideas ?
Code Basic4GL - [expand]
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
Device = 12F675
Config WDT_OFF, CPD_OFF, CP_OFF, MCLRE_OFF, BODEN_ON, INTRC_OSC_NOCLKOUT
'Setup system registers
ADCON0 = $81
ANSEL = $11
TRISIO = $1F
CMCON = $7
WPU = $16
OPTION_REG.7 = 0
GPIO = 0
'Global Variables
Dim adc_return As ADRESL.Word
Dim pos_value As Float
Dim servo_pos As Word
'Analog mode GP3 = 1
If GPIO.3 = 1 Then
  While 1 = 1
    ADCON0.1 = 1
    While ADCON0.1 = 1: Wend
    pos_value = adc_return/1024;
    servo_pos = (pos_value * 2000)+500;
    Servo GPIO.5, servo_pos
    DelayMS 5
  Wend
Else
  'Digital mode GP3 = 0
  servo_pos = 1500
  While 1 = 1
    'Down key control logic
    If GPIO.1 = 0 Then
      If servo_pos <= 510 Then
        servo_pos = 500
      Else
        servo_pos = servo_pos - $A
      EndIf
    End If
    'Up key control logic
    If GPIO.2 = 0 Then
      If servo_pos >= 2490 Then
        servo_pos = 2500
      Else
        servo_pos = servo_pos + $A
      EndIf
    End If
    'Reset key control logic
    If GPIO.4 = 0 Then servo_pos = 1500
    DelayMS 5
  Wend
EndIf
regards
Nils
The first line,
Device = 12F675
says that a device id for microcontroller is being used in the program.That way,it looks like,the compiler is most likely to be Microchip MPLAB.Which version of MPLAB is it...no clue.
Thanks !
I downloaded the free Proton lite compiler and it worked successfully.
Nils
