akanksha112
Newbie level 1
Hi All,
I have an 8 bit local signal which is used for some internal logic. Now the problem I am facing is when I am debugging using chipscope in the netlist signals , the 5th bit of the signal is trimmed and there is no warning or info regarding this.
I am sharing with you the pice of code related to this . I would be grateful if anyone of you could tell me any hint as to why this could happen. Earlier it was not giving any problem. It is a critical signal and I need to probe on it for my design so cant let go off it .
Here is the part of the code , THE SIGNAL IN QUESTION IS O_BYTE
PROCESS(CLOCK,RESET)
BEGIN
IF CLOCK'EVENT AND CLOCK = '1' THEN
IF RESET = '1' THEN
F_E <= '0' AFTER 1 NS;
F_D <= '0' AFTER 1 NS;
ELSIF ((B_SIZE = TRANS_LEN) OR (FLAG_S = '1')) THEN
ELSIF ((B_SIZE_2 = TRANS_LEN) OR (FLAG_S = '1')) THEN
ELSIF ((O_BYTE = X"0A") OR (O_BYTE = X"2A"))THEN
F_E <= '1' AFTER 1 NS;
ELSIF ((O_BYTE = X"28") OR (O_BYTE = X"08"))THEN
F_D <= '1' AFTER 1 NS;
END IF;
END IF;
END PROCESS;
BEGIN
IF RESET = '1' THEN
END IF;
END IF;
END PROCESS;
