zhi_yi said:okay, thank you
- why the BC557 can replaced with any general purpose pnp? is it mean that all of the general purposed pnp can be replaced with any other general purpose pnp and also for npn?
- what is the function of the bc557 in the schematic?
- is it the 74541 is buffer ic? what is the function of the buffer there?
- what is the function the crystal there? why should i give the clock to the µC when i want to burn the µC?
- why should i use 4MHz? why i can't replace it with the 12MHz?
thank you very much
zhi_yi said:hi there, please help me, can i use C9012 for the T1? in the schematic, it must be BC557, can i replace it with C9012?? and the 4MHz crystal, may i replace it with 12MHz crystal??
thank you
thank you
