- Joined
- Jan 22, 2008
- Messages
- 52,478
- Helped
- 14,756
- Reputation
- 29,794
- Reaction score
- 14,120
- Trophy points
- 1,393
- Location
- Bochum, Germany
- Activity points
- 298,337
Despite of the PWM modulation, you would need a 50 Hz transformer to step up this waveform (in terms of windings per volt respectively core size for a particular output power). You can e.g. filter the PWM and have a 50 Hz voltage, so you won't need to enable the transformer to transmit the PWM modulation. In other words, there's no mid frequency involved.I have the following waveform at the output of my Full-Bridge
Resonant converters are an option, but not the only reasonable way to operate a high frequency transformer. The option is frequently used for high power converters beyond 5 or 10 kW.I read somewhere that these transformers operate best at their resonant frequency.
You can transform a voltage of varying return-to-zero duty cycle, but not an asymmetric duty cycle without considerably increasing the turns per volt. So you effectively lose the advantages of a high frequency transformer.So they cannot be used to step up a high-frequency PWM having a 50Hz sine-wave embedded into its varying duty cycle.
Stepping up the input voltage to a constant DC bus voltage and chopping it to 50 Hz, with or without PWM, as mentioned by Audioguru is the most effective way to utilize a high frequency transformer.
