[PIC] proteus simulation error "eeprom data has invalid address[2000]"
OK.ME
Newbie
MY proteus simulation shows error for pic16f877a for the 7 sement 4 digit led display counter. my code is
#pragma config FOSC = EXTRC // Oscillator Selection bits (RC oscillator)
#pragma config WDTE = ON // Watchdog Timer Enable bit (WDT enabled)
#pragma config PWRTE = OFF // Power-up Timer Enable bit (PWRT disabled)
#pragma config BOREN = ON // Brown-out Reset Enable bit (BOR enabled)
#pragma config LVP = ON // Low-Voltage (Single-Supply) In-Circuit Serial Programming Enable bit (RB3/PGM pin has PGM function; low-voltage programming enabled)
#pragma config CPD = OFF // Data EEPROM Memory Code Protection bit (Data EEPROM code protection off)
#pragma config WRT = OFF // Flash Program Memory Write Enable bits (Write protection off; all program memory may be written to by EECON control)
#pragma config CP = OFF // Flash Program Memory Code Protection bit (Code protection off)
// #pragma config statements should precede project file includes.
// Use project enums instead of #define for ON and OFF.
#include <xc.h>
#define _XTAL_FREQ 20000000UL // 20MHz
unsigned char hexvalue[10]= {0x3F,0x06,0x5B,0x4F,0x66,0x6D,0x7D,0x07,0x7F,0x6F};
void main(void){
int a,b,c,d;
int i, j;
PORTCbits.RC0 = 0; // First Digit Bit Set as output
PORTCbits.RC1 = 0; // Second Digit Bit Ser as output
PORTCbits.RC2 = 0; // Third Digit Bit Set as output
PORTCbits.RC3 = 0; // Fourth Digit Bit Ser as output
PORTD = 0; // DATA pin FOR LCD 8bits port D as output
TRISD = 0; // Direction for Port D
TRISCbits.TRISC0= 0;//Set First bit direction
TRISCbits.TRISC1 = 0; // Set Second bit Direction
TRISCbits.TRISC2 = 0;//Set Third bit direction
TRISCbits.TRISC3 = 0; // Set Fourth bit Direction
while(1)
for (i=0;i<=9999;i++)
a = i/1000; // holds 1000's digit
b = ((i/100)%10); // holds 100's digit
c = ((i/10)%10); // holds 10th digit
d = (i%10); // holds unit digit value
for (j = 0; j< 10; j++){
PORTD=hexvalue[a]; // send 1000's place data to fourth digit
PORTCbits.RC0=0; // turn on forth display unit
__delay_ms(1);
PORTCbits.RC0=1; // turn off forth display unit
PORTD=hexvalue; // send 100's place data to 3rd digit
PORTCbits.RC1=0; // turn on 3rd display unit
__delay_ms(1);
PORTCbits.RC1=1; // turn off 3rd display unit
PORTD=hexvalue[c]; // send 10th place data to 2nd digit
PORTCbits.RC2 = 0; // turn on 2nd display unit
__delay_ms(1);
PORTCbits.RC2 = 1; // turn off 2nd display unit
PORTD=hexvalue[d]; // send unit place data to 1st digit
PORTCbits.RC3 = 0; // turn on 1st display unit
__delay_ms(1);
PORTCbits.RC3 = 1; // turn off 1st display unit
there is no any compilation error in mplab but in proteus segment display is shwing as expected and there is error showing "eeprom data has invalid address[2000]".
please help anyone i need to submit my clg project by tmrw.
I don't have Proteus but there is no mention of EEPROM in the code so I would guess you have a configuration error in Proteus itself and the code is good.
Brian.
I think there are two input sections for micrcontroller programming in proteus. One is for input hex of normalFlashROM and other is for hex of eeprom data.
Probably you are uploading compiled hex in eeprom input section in proteus instead of normal Program hex. Can you show us proteus config screen.
