[SOLVED] "Invalid Expression" problem
shivammun13
hello, i have been working on a code for a program which displays the number of counts on an LCD display. When count = 0 it should display Parking Full. When i compiled the code it says invalid expression. I used conversion to string before that but it did not work, so i wrote my code without string conversions.
Can anyone check and suggest why it is not compiling? Here my full code:
sbit GreenLED at RD6_bit;
sbit RedLED at RD7_bit;
sbit IncrementButton at RB1_bit;
sbit DecrementButton at RB0_bit;
sbit LCD_EN at RD0_bit;
sbit LCD_RS at RD1_bit;
sbit LCD_D4 at RD2_bit;
sbit LCD_D5 at RD3_bit;
sbit LCD_D6 at RD4_bit;
sbit LCD_D7 at RD5_bit;
sbit GreenLED_Direction at TRISD6_bit;
sbit RedLED_Direction at TRISD7_bit;
sbit IncrementButton_Direction at TRISB1_bit;
sbit DecrementButton_Direction at TRISB0_bit;
sbit LCD_RS_Direction at TRISD0_bit;
sbit LCD_EN_Direction at TRISD1_bit;
sbit LCD_D4_Direction at TRISD2_bit;
sbit LCD_D5_Direction at TRISD3_bit;
sbit LCD_D6_Direction at TRISD4_bit;
sbit LCD_D7_Direction at TRISD5_bit;
int count = 10;
const int MAX_COUNT = 10;
void main() {
GreenLED_Direction = 0;
RedLED_Direction = 0;
IncrementButton_Direction = 1;
DecrementButton_Direction = 1;
Lcd_Init();
Lcd_Cmd(_LCD_CLEAR);
Lcd_Cmd(_LCD_CURSOR_OFF);
Lcd_Out(1, 1, "P.SLOT LEFT:");
Lcd_Out(1, 13, "10");
while(1) {
 if (!DecrementButton) {
    count = count-1;
    if(count < 0){
       count = 0;
       if (count == 0) {
        GreenLED = 0;
        RedLED = 1;
        } else {
        GreenLED = 1;
        RedLED = 0;
        while (!DecrementButton);
 if (!IncrementButton) {
     count=count+1;
     if (count > MAX_COUNT) {
        count = MAX_COUNT;
      if (count > 0){
      GreenLED = 1;
      RedLED = 0;
      } else{
      GreenLED = 0;
      RedLED = 1;
      while (!IncrementButton);
    if (count == 10) {
    Lcd_Out(1, 13, "  ");
    if (count == 9) {
    Lcd_Out(1, 13, "9");
    if (count == 8) {
    Lcd_Out(1, 13, "8");
    if (count == 7) {
    Lcd_Out(1, 13, "7");
    if (count == 6) {
    Lcd_Out(1, 13, "6");
    if (count == 5) {
    Lcd_Out(1, 13, "5");
    if (count == 4) {
    Lcd_Out(1, 13, "4");
    if (count == 3) {
    Lcd_Out(1, 13, "3");
    if (count == 2) {
    Lcd_Out(1, 13, "2");
    if (count == 1) {
    Lcd_Out(1, 13, "1");
    if (count == 0) {
    Lcd_Out(1, 13, "0");
    Lcd_Out(2, 3, "PARKING FULL");
Solution
You are missing the closing bracket (from main). If you change the formatting so each bracketed expression or function is indented it look like this:
sbit...
int count = 10;
void main()
  Lcd_Init();
  while(1)
      count = count-1;
      if(count < 0)
        count = 0;
      if (count == 0)
        GreenLED = 0;
        RedLED = 1;
      else
        GreenLED = 1;
        RedLED = 0;
      count=count+1;
          count = MAX_COUNT;
      if (count > 0)
          GreenLED = 1;
          RedLED = 0;
        else
          GreenLED = 0;
          RedLED = 1;
      if (count == 10)
      if (count == 9)
      if (count == 8)
      if (count == 7)
      if (count == 6)
      if (count == 5)
      if (count == 4)
      if (count == 3)
      if (count == 2)
      if (count == 1)
      if (count == 0)
and you can see your closing bracket matches the while statement instead of main.
Very messy and over complicated display routine.
Brian.
Solution
int count = 10;
void main()
  Lcd_Init();
  while(1)
      count = count-1;
      if(count < 0)
        count = 0;
      if (count == 0)
        GreenLED = 0;
        RedLED = 1;
      else
        GreenLED = 1;
        RedLED = 0;
      count=count+1;
          count = MAX_COUNT;
      if (count > 0)
          GreenLED = 1;
          RedLED = 0;
        else
          GreenLED = 0;
          RedLED = 1;
      if (count == 10)
      if (count == 9)
      if (count == 8)
      if (count == 7)
      if (count == 6)
      if (count == 5)
      if (count == 4)
      if (count == 3)
      if (count == 2)
      if (count == 1)
      if (count == 0)
Brian.
Thanks man! Actually i started using conversions to convert the counts to strings but i was having a lot of problems and the lcd was not displaying the counting. As a result i tried doing it this way. I don't know if this will work. I just hope it displays the counting sequence🙂
