Problem with RN-XV Wi-Fly modul and 8051 microcontroller
Keklja
Junior Member level 2
I need huge help. I connected my RN-XV module https://www.sparkfun.com/products/10822 to board (see attachment). 4 pins from RN-XV (5V,GND,TXT,RXT) I connected to IC106(see on scheme), 5V-slot 8, GND- slot 5, TX- 1, RX- 4. Jumper J102 I switched to left position so I could use RX. When it is connected like this I cant use my serial port so only way to configure module is to enable add-hoc mode manually. To do so pin PIO9 must be set to high (3.3V) at power up. I have this **broken link removed** and I connect this PIO9 pin to 3.3V. When I power on board nothing happens. Leds on module (green and red) blink simultaneously and laptop cant see this network that module create in add-hoc mode. Any ideas what is wrong and how to fix it?
Im thankful for any tips..
  • scheme.rar
