problem in initialization
JoseNaveen
Newbie level 5
hi.. i have a vhdl code for uart transmitter ..when i simulate it the signal n_reg is not getting initialized and remains in uninitialized state..can someone help me with this..? i have attached the code and the simulation snapshot..
  • uart_tx.rar
I have done a quick simulation with your uart code and in my simulator n_reg will be '0' after reset.
From your simulation picture I can not see how long the reset pulse is and how it behaves compared to the clock. Maybe you can post your testbench code also so I can use it with my simulator to see that n_reg still be initialized after reset.
Devas
My guess is you didnt connect reset to the reset port in the testbench.
May I also recommend the 1 process state machine - there is not need to worry about latches. And it is also alot easier to follow.
thank u both ..i'll try to test with a new testbench..
