Plz help me to link these modules in verilog
nitheeshnas
i am doing a project on designing an ic for controlling the speed of a dc motor . the main modules in my project are pwm ,encoder,counter and pid..
i have generated the codes for counter, pid and pwm seperately but when i try to link it ..i am not getting it right ...plz help me..
these are my there modules
1,counter
Code Verilog - [expand]
8
9
10
11
12
13
14
15
16
17
18
19
20
module count(clk,a,out,r,n,e);
input clk;
input a;
input [7:0]r;
input [7:0]n;
integer counter=0;
output reg [7:0]e;
output reg [7:0]out;
reg [7:0]temp;
always @ (a)
begin
    if (a==1) counter=counter+1;
    temp=(counter/r);
    out=(temp*n);
    if
    (out>=200) e=out-200;
    else
    e=200-out;
    end
    endmodule
2,pid
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
module PIDdddd(u_out,e_in,clk,reset,u);
output signed [15:0] u_out;
output signed [15:0] u;
input signed [15:0] e_in;
input clk;
input reset;
parameter k1=107;
parameter k2 = 104;
parameter k3 = 2;
reg signed [15:0] u_prev;
reg signed [15:0] e_prev1;
reg signed [15:0] e_prev2;
assign err=(e_in/5);
assign u =(u_prev)+(k1*err)+(k3*e_prev2);
assign u_out = u+(-(k2*e_prev1));
always @ (posedge clk)
if (reset == 1) begin
u_prev <= 0;
e_prev1 <= 0;
e_prev2 <= 0;
end
else begin
e_prev2 <= e_prev1;
e_prev1 <= err;
u_prev <= u_out;
end
endmodule
3,pwm
8
9
10
11
12
13
14
15
module pulse(clk,switches,pwm);
    input clk;
    input [16:0] switches;
    output pwm;
    reg pwm;
    reg [15:0] counter=0;
    parameter sd=195;
    begin
        counter=counter+5;
        if(counter<=switches*sd) pwm=1;
        else pwm=0;
       if (counter>=50000) counter=0;
     end
 endmodule
and i want to connect these 3 modules that is i want to input the output of counter to pid and output of pid to pwm...plz help me
If it just how to connect between 3 modules, then..
you can create another module as a top module and connect all your modules(counter, pid etc...) inside this top module as what you said
how will i do it..can u help me plz....or show me an example...
you can create a top module where you can instantiate all the other modules. like as follows ..
module TopModule(outputs & inputs here of the whole box containing the small boxes);
output ...
input .....
wire *instantiate some wires here to connect the modules among themselves*
//Now instantiate the modules in the following code. Read up on module instantiation. Just google it. Its pretty simple.
count counteri1(.............)
pid pidi1(...........)
pulse pulsei1(.............)
endmodule
You must draw a simple draft diagram showing what exactly do you want to connect.
Technically speaking you *should* TEST your individual modules first! And, by including them into a testbench file individually to make sure they work as expected in simulation, you will also learn how to connect them up in an upper level file to each other!
here i am adding the code for 3 modules counter,pid and pwm...plzz help me to link these three modules....in such a way that i want the output of counter to be given as the error signal input of pid(e_in) and the out put of pid (u_out) as the the input of pwm(switches)....plzz help....thanks in advance..
input clk;
input a;
input [7:0]r;
input [7:0]n;
integer counter=0;
output reg [7:0]e;
reg [7:0]temp;
always @ (a)
begin
    temp=(counter/r);
    out=(temp*n);
    if
    else
    e=200-out;
    end
    endmodule
input clk;
input reset;
parameter k1=107;
parameter k2 = 104;
parameter k3 = 2;
u_prev <= 0;
e_prev1 <= 0;
e_prev2 <= 0;
end
else begin
e_prev2 <= e_prev1;
e_prev1 <= err;
u_prev <= u_out;
end
endmodule
    input clk;
    output pwm;
    reg pwm;
    parameter sd=195;
    begin
        counter=counter+5;
        else pwm=0;
     end
 endmodule
As said before, excepting in/out definitions, the content inside each functional block don´t matter.
You must express it terms of diagram, what exactly do you want connect to what.
