jugemu1234
Newbie level 5
ocean script
I am very new to SKILL or ocean script . I have problems with following script. Firstly I created this ocean.ocn by ADE>Session>Save ocean script... Then added some lines to output data to file. However it ends up outputing error after successful simulation but I do not know what is wrong with this then tried to figure out by myself but couldnt.
I am sure this would be easy thing to do for some people. Hope someone help me out at the earliest oppotunity.
Thanks in advance.
ocnWaveformTool( 'awd )
simulator( 'spectre )
design( "/netlist")
resultsDir( "/MydfII/simulation/sim_osc2/spectre/schematic" )
path( "/multiplelib" )
modelFile(
'("active_thin.scs" "tt")
analysis('tran ?stop "1.1u" ?errpreset "conservative" ?write "spectre.ic"
?writefinal "spectre.fc" ?annotate "status" ?finalTimeOp t ?maxiters "5"
?threshold "0.0" ?detail "node" ?sort "name" )
desVar( "Lvar" 1 )
save( 'v "/net019" "/dvss!" "/dvdd!" )
temp( 27 )
out = outfile("results.txt" "a")
run()
results()
selectResults('tran)
outputs()
ocnPrint(?output out frequency(clip(VT("/net019"),1u,1.1u)) )
close(out)
Thanks in advance.
design( "/netlist")
modelFile(
desVar( "Lvar" 1 )
temp( 27 )
run()
results()
outputs()
close(out)
