DXNewcastle
Full Member level 4
- Joined
- Jan 8, 2011
- Messages
- 201
- Helped
- 77
- Reputation
- 154
- Reaction score
- 73
- Trophy points
- 1,308
- Location
- Newcastle, UK
- Activity points
- 3,259
Yes, its most likely to be thermal noise, and next most likely to be RF. I'm trying to get enough accurate data from you to work out where its coming from, which is why I'm pressing you for precise facts.. . . .
I use 3k.
I use e-cap 16V and its most positive end is properly connected to the positive end of microphone.
Just one thing that I would like to stress out here, why on earth does the preamp only works in the first 6s? Was it just like what you said? Thermal noise?
You haven't yet reported back the impedance of the microphone and whether a v.smal cap between base and collector reduced the noise.
But even after correcting the transistor data, and still not knowing the impedance of the microphone, there's still a contradiction in your evidence!
If you used a 3k resistor instead of the microphone, then the positive end of C1 should have been at 1.5volts and the negaitive end should have been at 3.6volts. i.e. the positive end should have been more negative than its positive end. This can result in noise after a short period. Would you please re-test that when you have the resistor in place instead of the microphone, and again when you have the microphone in place instead of the resistor and confirm the voltages.
Do we know any more yet about the powering requirements of the microphone? eg how many milli-amps of what voltage and at what impedance?
