Legris
Newbie level 6
This is my existing code :
Can anyone help me how to get the S4 to turn on the LED and button S3 to turn off the LED.
Please help me guys !
Im really stuck !!
Appreaciate if you would help !
PHP:
#include "p24FJ128GA010.h"
#include "system.h"
// Set up configuration bits
_CONFIG1( JTAGEN_OFF & GCP_OFF & GWRP_OFF & COE_OFF & FWDTEN_OFF & ICS_PGx2)
_CONFIG2( FCKSM_CSDCMD & OSCIOFNC_ON & POSCMOD_HS & FNOSC_PRI )
// Set up user-defined variables
int main(void)
// Set up PortA IOs as digital output
AD1PCFG = 0xffff; // Set all shared analog/digital I/O pins to digital
TRISA = 0x0000; // Set port A to output as LED driver
BtnInit(); // Initialize for Button handling
while (1)
BtnProcessEvents(); // Check Button
if (_button_press.b4) // Process the following if Button 4 is pressed and settled
PORTAbits.RA0 ^= 1; // toggle LED 'D3'
while (_button_press.b4) // Wait for Button 4 to release
// while (BtnIsPressed(4)) { // Wait for Button 4 to release
// BtnProcessEvents();
else (_button_press.b3)
PORTAbits.RA0 ^= 0;
}// End of while loop...
}// End of main()...
#include "system.h"
unsigned char _b4_cnt;
unsigned char _b3_cnt;
BUTTON _button_press;
//store old tris values for button I/O pins
unsigned int b4tris;
unsigned int b3tris;
void BtnInit(void)
TRISDbits.TRISD13=1; // Set bit 13 of PORTD as input (to sense the logic level of push button 4)
// Note: RD13 from PORT D is connected to Push Button S4 on the Explore16 board
TRISDbits.TRISD6=1; // Set bit 6 of PORTD as input.
// Note: RD6 from PORT D is connected to Push Button S3 on the Explorer 16 Board
_b4_cnt = 128; // Initialize debounce counter for button 4 to neutral value
_b3_cnt = 128;
void BtnProcessEvents(void)
if (!BUTTON4) { // The following branch is when BUTTON4 is '0' (i.e. DEPRESSED)
_b4_cnt++; // Increment debounce counter
if (_b4_cnt >= (128 + BUTTON_MAX_DEBOUCE)){ // The following is for BUTTON4 finally settles at '0'
_b4_cnt = (128 + BUTTON_MAX_DEBOUCE); // Stick to the maximum value
_button_press.b4 = 1; // Set flag for Button 4 to indicate it is depressed
else { // The following branch is when BUTTON4 is '1' (i.e. RELEASED)
_b3_cnt--; // Decrement debounce counter
if (_b3_cnt <= (128 - BUTTON_MAX_DEBOUCE)){ // The following is for BUTTON4 finally settles at '1'
_b3_cnt = (128 - BUTTON_MAX_DEBOUCE); // Stick to the minimum value
_button_press.b3 = 0; // Set flag for Button 4 to indicate it is released
*HEADER FILES *
#define BUTTON4 PORTDbits.RD13
#define BUTTON3 PORTDbits.RD6
void BtnInit(void);
void BtnProcessEvents(void);
typedef struct tagButton
unsigned b4:1;
unsigned b3:1;
}BUTTON;
extern BUTTON _button_press;
#define BUTTON_MAX_DEBOUCE 20
extern unsigned char _b4_cnt;
extern unsigned char _b3_cnt;
#define BtnIsPressed(__btn) _button_press.b##__btn
#define BtnIsNotPressed(__btn) !_button_press.b##__btn
Im really stuck !!
