cryptopsii
Newbie level 3
I have a circuit that has to receive a low-duty pulse, emitted from a IR LED 1-2 meters away. The wave does not use a carrier or any form of modulation so the receiver is also pretty simple.
The receiver use an IR photodiode of a matching wavelength. Here the schematic:
(or https://www.freeimagehosting.net/uploads/1e4bb80d94.png whatever)
This circuit work ok, but it has ZERO noise protection, so if there is sun, the diode produce a constant amount of dc. the same is true for indoor lights. (except it produce 60hz instead of dc)
So I thought about simply using a high-pass filter since the signal i receiver is around 1kHz but i just can't figure where to put the capacitor & resistor...
the opamp is a obscure NMJ062 and is dual package, so if your solution imply a voltage follwer or any dual-op amp configuration it's fine. Also, the opamp isn't
rail-to-rail (It's like -.5V on each rail)
So any help/suggestion / better design idea would be greatly appreciated.
![1e4bb80d94.png](https://www.freeimagehosting.net/uploads/1e4bb80d94.png)
