harinisas
Newbie level 6
Hi all
i have written a simple code for IRQ interrupt which should display one led pattern before interrupt and other after interrupt has occurred. the interrupt is an external interrupt EINT0. i dont have any errors in code i even made changes in the startup file but even then i am not able to see the output on the board after loading it.......pls say what d error is and what changes i should i make in startup file for intterupts so dat i get the output ..
its urgent pls hep me.......
the code is
the code is
Code C - [expand] 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 #include "LPC23xx.h" void delay(void) //delay function { int i; for (i = 0; i <=10000000;i++); } void INT0_ISR() __irq { FIO2CLR = 0X000000FF; delay(); FIO2SET = 0X000000AA; EXTINT = (1 << 0); // Clear the Interrupt Flag for EINT0 VICVectAddr = 0; } int main() { FIO2DIR = 0X000000FF; FIO2CLR = 0X000000FF; PINSEL4 = (1 << 20); EXTMODE = 0X00; // Set as Level Sensitive EXTPOLAR = 0X00; // Set as low active VICIntSelect = 0X00; // Set VIC Interrupt slot as IRQ Request VICVectPriority14 = 0X00; // Set the Higest priority for the VIC Interrupt Slot VICVectAddr14 = (unsigned) INT0_ISR; // Load the ISR Address to Address Register VICIntEnable = (1 << 14); // Enable the INT0 Slot FIO2SET = 0X00000055; while(1); return 0; }
