Ali Hamad
Hi guys, I hope you are fine and happy
I need help from you, please , I want to design dynamic RAM in VHDL, but befor that , I would like to anderstand StaticRAM ,so I did it BUT I could not simulat it so, I 'll show to you and if you have easier way than it, please show me it, thanks
this is source code ....... .
ibrary IEEE;
use IEEE.STD_LOGIC_1164.ALL;
entity tryRAM_sor is
generic( width: integer:=4;
depth: integer:=4;
addr: integer:=2);
Port ( clock : in STD_LOGIC;
enabl : in STD_LOGIC;
read_t : in STD_LOGIC;
write_t : in STD_LOGIC;
read_addr : in STD_LOGIC_VECTOR (1 downto 0);
write_addr : in STD_LOGIC_VECTOR (1 downto 0);
data_in : in STD_LOGIC_VECTOR (3 downto 0);
data_out : out STD_LOGIC_VECTOR (3 downto 0));
end tryRAM_sor;
architecture Behavioral of tryRAM_sor is
type ram_type is array (0 to depth-1) of
std_logic_vector(width-1 downto 0);
signal tmp_ram: ram_type;
begin
-- Read Functional Section
process(Clock, Read_t)
begin
if (Clock'event and Clock='1') then
if Enabl='1' then
if Read_t='1' then
-- buildin function conv_integer change the type
-- from std_logic_vector to integer
else
Data_out <= (Data_out'range => 'Z');
end if;
end if;
end if;
end process;
-- Write Functional Section
process(Clock, Write_t)
begin
if Enabl='1' then
if Write_t='1' then
end if;
end if;
end if;
end process;
end Behavioral;
This is test banch
LIBRARY ieee;
USE ieee.std_logic_1164.ALL;
-- Uncomment the following library declaration if using
-- arithmetic functions with Signed or Unsigned values
--USE ieee.numeric_std.ALL;
ENTITY tryRAM_tb IS
END tryRAM_tb;
ARCHITECTURE behavior OF tryRAM_tb IS
-- Component Declaration for the Unit Under Test (UUT)
COMPONENT tryRAM_sor
PORT(
clock : IN std_logic;
enabl : IN std_logic;
read_t : IN std_logic;
write_t : IN std_logic;
read_addr : IN std_logic_vector(1 downto 0);
write_addr : IN std_logic_vector(1 downto 0);
data_in : IN std_logic_vector(3 downto 0);
data_out : OUT std_logic_vector(3 downto 0)
END COMPONENT;
--Inputs
signal clock : std_logic := '0';
signal enabl : std_logic := '0';
signal read_t : std_logic := '0';
signal write_t : std_logic := '0';
signal read_addr : std_logic_vector(1 downto 0) := (others => '0');
signal write_addr : std_logic_vector(1 downto 0) := (others => '0');
signal data_in : std_logic_vector(3 downto 0) := (others => '0');
--Outputs
signal data_out : std_logic_vector(3 downto 0);
-- Clock period definitions
constant clock_period : time := 10 ns;
BEGIN
-- Instantiate the Unit Under Test (UUT)
uut: tryRAM_sor PORT MAP (
clock => clock,
enabl => enabl,
read_t => read_t,
write_t => write_t,
read_addr => read_addr,
write_addr => write_addr,
data_in => data_in,
data_out => data_out
process
begin
Clock<='1'; -- clock cycle 10 ns
wait for 50 ns;
Clock<='0';
wait for 50 ns;
end process;
process
begin
enabl <= '1';
read_t <= '0';
write_t <= '0';
write_Addr <= ( Write_Addr'range => '0');
read_Addr <= ( Read_Addr'range => '0');
data_in <= ( Data_in'range => '0');
wait for 200 ns;
-- test write
for i in 0 to 3 loop
Write_Addr <= Write_Addr + "1";
Data_in <= Data_in + "10";
Write_t <= '1';
wait for 100 ns;
end loop ;
assert (T_Data_out="ZZZZ")
-- test read
for i in 0 to 2 loop
read_Addr <= (read_Addr + 1);
read_t <= '1';
wait for 100 ns;
end loop;
wait;
end process;
END;
ibrary IEEE;
depth: integer:=4;
addr: integer:=2);
end tryRAM_sor;
begin
begin
if Enabl='1' then
if Read_t='1' then
else
end if;
end if;
end if;
end process;
begin
if Enabl='1' then
if Write_t='1' then
end if;
end if;
end if;
end process;
end Behavioral;
This is test banch
LIBRARY ieee;
ENTITY tryRAM_tb IS
END tryRAM_tb;
PORT(
END COMPONENT;
--Inputs
--Outputs
BEGIN
clock => clock,
enabl => enabl,
read_t => read_t,
write_t => write_t,
data_in => data_in,
process
begin
wait for 50 ns;
Clock<='0';
wait for 50 ns;
end process;
process
begin
enabl <= '1';
read_t <= '0';
write_t <= '0';
wait for 200 ns;
-- test write
Write_t <= '1';
wait for 100 ns;
end loop ;
-- test read
read_t <= '1';
wait for 100 ns;
end loop;
wait;
end process;
END;
