modelsim log appending #
meir
Junior Member level 3
modelsim is creating log file with '#' at the beginning of every line
is there a way to prevent this ?
sed 's/^#//g' < my_favorite_logfile.log
There we go, workaround. ;-)
As for fixing the underlying problem, I don't know the answer to that one. But wait a bit and no doubt dave_59 can tell you the answer in 3 seconds.
You can add a LinePrefix variable setting in the modelsim.ini file or add set PrefMain(LinePrefix) "" to your script.
The reason for the '#''s is so that you can use your log file as a script to recreate your simulation.
