reedlaw
Newbie level 1
I've designed a board with analog and digital signals where I've tried to isolate the analog section. I've read about the benefits of keeping analog and digital ground on the same plane. One question I have is should the analog ground be tied directly to the power supply ground, or have to go back through the ferrite and power filters before reaching the power supply ground?
Here's my circuit:
As you can see the bright red section is analog ground. The power supply jack is in the bottom right. At this point, the analog ground is not connected directly to the power jack. I'm not very clear about what ferrite does to help keep the signal free from interference.
You can read more about it and download the Eagle files **broken link removed**.
Here's my circuit:
