umer_366
Member level 2
hi all
i am attaching ADC with the miceoblaze and ADC works with 30 MHz clock speed .
while my FFT core and VGA works at 50 MHz clock speed and i have attached them with the microblaze.
system clock is of 50 MHz..
can i use DCM to make a connection these 3 design with the same microblaze???
the reason what i have found is that thereis a global buffer which is used by the microblaze to make the 50 MHz clock stable....
and whenever i use DCM to convert the 50 MHz to 30 MHz then it does not result with the microblaze...
is there any limitation like that???
or there may be some other reason???
thanks
thanks
