x_ngine
Junior Member level 3
I'm designing a circuit with several power regulators and ICs.
One of the requirements is to be able to measure the current on each rail. The first option is to add some small shunt resistors in series to the regulators, another, as requested by my client, is to have the possibility to instrument a wire loop to sense the current using a handheld magnetic current meter.
Usually, when I need to do so, I replace the shunt with a wire loop, but my client does not want to have to rework the board to do so. Assuming the shunt resistor is unstuffed the client wants a way to quickly install a wire loop.
What are my options?
1) Are there wire loops that can be installed as a component? I could have a BOM variant where the wire loops are installed instead of the shunts.
2) Is there any header/connector that can be used to add a wire loop? Something I will connect in parallel to the shunt resistor... I wonder, in this second case, how much would the parasitic series resistance be.
Thanks
Thanks
