[SOLVED] LTC2440 How to Read and How to Configure ?
Okada
Banned
I am designing a Weighing Scale and want to use LTC2440. I want to know how to Configure the resolution of the LTC2440 to 24 bit.
In device datasheet page no. 14 table 3 provides the OSRx values to be written to the device using its SDI pin. Should I write 0x08 serially to configure the device to output 24 bit adc result ?
If yes, When should I write this value ? While reading the device ?
This is the code I have written but I am getting 0.
Code C - [expand]
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
void LTC2440_Init() {
    LTC2440_SCK_Direction  = OUTPUT;
    LTC2440_SDO_Direction  = INPUT;
    LTC2440_CS_Direction   = OUTPUT;
    LTC2440_SDI_Direction  = OUTPUT;
    LTC2440_CS = HIGH;
    LTC2440_SDI = LOW;
unsigned long int Read_LTC2440(unsigned char input_data) {
    unsigned char i = 0, mask = 0x10;
    unsigned long int result = 0;
    LTC2440_SCK = LOW;
    Delay_ms(1);
    LTC2440_CS = LOW;
    Delay_ms(1);
    if(!LTC2440_SDO) {
        Delay_ms(1);
        for(i = 0; i < 32; i++) {
            if(input_data & mask) {
                LTC2440_SDI = HIGH;
            else {
                LTC2440_SDI = LOW;
            Delay_ms(1);
            input_data <<= 1;
            LTC2440_SCK = HIGH;
            Delay_ms(1);
            if(LTC2440_SDO) {
               result |= 1;
            result <<= 1;
            LTC2440_SCK = LOW;
            Delay_ms(1);
    }    Delay_ms(5);
    LTC2440_CS = HIGH;
    return (result & 0x3FFFFFFF) >> 6;
raw_adc_value = Read_LTC2440(0x18);
Delay_ms(1);
Edit: I got the output but it is not correct. I am getting x2 value ? Why ? Circuit is same as in previous post. For 2.5V input I am getting 5.0V.
weight = (double)raw_adc_value * 5.0 / 16777216.0;
This i sonly a test code.
Edit:
Got the required output. See attached simulation video. I have set max weight to be measured as 1000 Kg in code and I am getting precise result.
  • Weighing Scale - Proteus Simulation Result.pdf
  • Proteus Simulation Video #4.rar
