?? I believe a sine waveform has exactly two zero crossings per cycle. How do you add zero crossing (and maintain the sine waveform)?adding a zero crossing in this sinewaveform
That's how the waveform seems to be generated, isn't it?But what do you mean by inserting a delay between output voltage halfcycles?
And the blue waveform shows the intended current? Did you already sketch the related voltage waveform?It is a RLC load with quality factor of 2.5.
