interface Atmega32 with rs232 and max 232....
hanukaran
Junior Member level 2
now i wan sen data to be shown in pc.I use visual basic for that. now the problem how to write the coding to send the data to rs232...can anyone help me...i have attached my coding and my schematic of circuit and the interface
  • project.rar
here i attach the files....sorry
  • project.rar
If I understand correctly you are asking for help on the pc side communication software, not the mcu code.
I'm not not sure if this is the right category for that.
Alex
If this is your problem (sending data from controller to PC) , here's a sample program.
// USART0 initialisation
void USART0_Init(unsigned short int F_CPU_MHz, unsigned short int Baud_Rate)
Description:	Initialize the UART0 hardware with the required BaudRate
Input:			Frequency of the Microcontroller, Desired BaudRate
Output:			None
	UCSR0B = 0x00; 										// Disable while setting baud rate
	UCSR0A = 0x00;										// Disable USART flags
	UCSR0C = (1<<USBS0)|(1<<UCSZ01)|(1<<UCSZ00);		// 8-Bit data, 1-Bit Stop
	UBRR0L = ((F_CPU_MHz*1000000)/Baud_Rate/16)-1;		// Set Baud Rate Lo - Asynch Normal Mode
	UBRR0H = 0x00; 										// Set Baud Rate Hi
	UCSR0B = (1<<RXEN0)|(1<<TXEN0);					// Enable USART TX and RX
// Send a single byte to the computer
void Send_Byte(char data)
Description:	Send a single byte on the UART port
Input:			A character to be sent
Output:			None
    while ((UCSR0A & (1<<UDRE0)) == 0);
	UDR0 = data;
// Receive a single byte from the computer
char Receive_Byte(void)
Description:	Receive a single byte on the UART port
Input:			None
Output:			A character with the received byte
    while((UCSR0A&(1<<RXC0)) == 0);
    return UDR0;
thanks for your answer and valuable time.....in my c# coding which i attach .... while (1)
red_1=0;
red_2=1;
green_1=1;
delay_green();
green_1=0;...............
if red_1=0..should send data to pc that will shown in Vb then it will return to red_2..how to edit this....
