How u define Corners Sims(LTRAN & RTRAN)..
pnanda65675
Member level 2
ltran ic
How u define LTRAN & RTRAN in term of TEMP & VDD...
i know LTRAN has n-type MOS fast,p-type MOS slow & on the contrary RTRAN is n-type MOS slow, p-type MOS fast...but im still clueless about fixing the Temperature & supply for my sims...DO anybody have the info about this
ltran rtran
Can somebody pls reply for earlier post.....
You use HSPICE?
Added after 1 minutes:
Google for "CMOS +PVT",you will find the answer.
You need simulate various combination for corners and different VDD and different temperature. At the least, the highest and lowest VDD and -40degree and 100degree are needed.
you can use the .param to change the source voltage.
