how to truncate the corners of the patch in hfss
vishal_sonam
Full Member level 3
Hello, i want to that how can i cut the corners of the patch or truncate the corners in hfss.
i m working in this attached paper, i have cutted all the slits but i m not able to cut the corners. please somebody help me in this.
regard
vishal
  • 06159140.pdf
Hello Vishal
from the paper you can see the dimensions of the triangular to be truncated. Draw a triangle using the lines and then use the Boolean function and subtract it from the trace .
Hope that helps
Elchiquito
Hello Elchiquito
can you please check my file.
i think it has no problem and i have designed it correctly but it still give the message of adaptive passes and still results are not matching
  • paper.rar
Vishal
I will check your file and let you know. what is the error or message of adpative passes, that they didnt converge or did they converge?
Elchiquito
[warning] Adaptive Passes did not converge based on specified criteria. (11:39:22 PM Mar 22, 2012)
i have set the centre frquency for 3 GHz and adaptive passes also 3 and then 6 but still getting this message
Increase the number of passes to 15 and see if they converge. none convergence implies faulty results.
Elchiquito
