SIQ
Newbie level 6
As I do not have pure 75ohm VNA available, I would like to know may I use typical VNA (like 8364) with 50ohm environment (ie, 50ohm test port, cable, adapter etc.) to test 75 ohm part (coaxial interface). The S parameter should be finally renormalized to 75ohm?
My thoughts are as following:
1. Use standard 50 ohm calibration kit to do SOLT Cal., but setting the “system imp” to be 75ohm. Does the tested S parameter is renormalized to 75ohm?
2. Use the standard procedure as do 50 ohm SOLT Cal (ie, system imp still to be 50ohm), the tested S parameter then go to ADS for post-processing, renormalized to be 75ohm.
I am not sure if both methods work. If do, which method is better?
Many thanks!
Many thanks!
