How to select and plot individual results of parametric sim
lagos.jl
Member level 1
cmos53.scs
Hi all!.
After reading the related Cadence documentation and searching through the web I haven't been able to figure out the Skill /Ocean code needed to 'grab'
and plot individual results from a parametric analysis.
Please consider the following sample code:
; Sample_simulation_individual_steps.il
ocnWaveformTool( 'wavescan )
simulator( 'spectre )
design( "/home/cdsmgr/cds/tesis/Sim/GIAPRI/spectre/schematic/netlist/
netlist")
resultsDir( "/home/cdsmgr/cds/tesis/Sim/GIAPRI/spectre/schematic" )
modelFile( '("/programs/cadence/DESIGN_KITS/ams_v3.70/spectre/c35/
mcparams.scs" "")
'("/programs/cadence/DESIGN_KITS/ams_v3.70/spectre/c35/cmos53.scs"
"cmostm") )
analysis( 'dc ?param "IAPR_cero" ?start "0" ?stop "1" )
load("Cargar_Variables_Diseno_Tesis.il")
desVar( "IINTs_menos1" 0.5 )
desVar( "IAPR_cero" 0.5 )
temp( 27 )
save( 'i "/DUT/IAPRI_uno" "/DUT/IAPRI_cero" )
paramAnalysis( "IINTs_menos1" ?values '(0.01 0.5 0.99 ) ?sweepType
'paramset )
paramRun()
;Selection of an individual (first) step of the parametric set
selectResult( 'dc car(sweepValues()) )
; Signal IAPRI_cero
pIAPRI_cero = (IDC("/DUT/IAPRI_cero") / (IDC("/DUT/IAPRI_cero") +
IDC("/DUT/IAPRI_uno")))
plot( pIAPRI_cero ?expr '( "pIAPRI_cero" ) )
addSubwindowTitle( "IAPRI_cero" )
; Signal IAPRI_uno
pIAPRI_uno = (IDC("/DUT/IAPRI_uno") / (IDC("/DUT/IAPRI_cero") + IDC("/
DUT/IAPRI_uno")))
plot( pIAPRI_uno ?expr '( "pIAPRI_uno" ) )
addSubwindowTitle( "IAPRI_uno" )
;end.
Without the "selectResult" line, it runs fine but plots the entire
curve families for both generated signals. When I add the
"selectResult" line, which I took from CH7 in the Ocean Ref. manual -
under the description for this command (BTW: the line there seems to
be mistyped, as it reads "selectResult(( 'tran car( sweepValues() )" -
parentheses mismatch), not only don't I get the desired result but it
also throws me the following error (I guess it's sweepValues
complaining):
\o You must do openResults() and selectResults() before using
\o this command. Make sure your openResults() and
\o selectResults() commands worked. Use ocnHelp('openResults)
\o and ocnHelp('selectResults) for more information.
I have tried including lines like "selectResult('dc)" or using the
openResults command before the aforementioned line, but with no luck.
I would be really grateful if someone could please give me a hint on
how to figure this out. Thanks in advance for any help/ideas/
comments! :)
Regards,
Jorge Luis.
Re: cmos53.scs
I have the same question here. Trying to export the result for gm/Id chart.
Hi all!.
netlist")
mcparams.scs" "")
"cmostm") )
temp( 27 )
'paramset )
paramRun()
; Signal IAPRI_cero
; Signal IAPRI_uno
DUT/IAPRI_uno")))
;end.
complaining):
comments! :)
Regards,
Jorge Luis.
